Still No Spark!! Replaced almost everything!
No spark.  Just bought bike
Checked ohms on stator, pickup, coil primary and seconday, wires and caps. ALL.TEST GOOD. Continuity in on/off/light switch is good....(although it beeps continuity on OFF. Dont think this should effect spark as long as i have it on OFF, aka, the new ON.) Key switch has good continuity.
Has a tors delete. Everything unplugged and/or cut.
BRAND NEW. I replaced or replaced with:
Flywheel, Stator, wire harness, key switch, cdi box stage 2 , voltage regulator, keyway, dynatek coil
Only thing i didnt test was cdi box because i couldnt find anything on that.
The fact that you said the CDI box is Stage 2 tells me it is not OEM. I tried an aftermarket box because it was all I could get in St. Anthony's- it lasted 1 ride. You can't test a CDI box, the test is to swap in a known good box. Get an OEM stator and CDI box, then you won't be chasing  your tail. Did you check the pickup coil gap to the flywheel?
