Gibby84 Posted September 28, 2020 Report Posted September 28, 2020 Have Toomey T6 pipes, Toomey 2in1 filter, stock carbs 300 mains clip in middle, 25 Pilot. I reside in Michigan. What would a 27.5 pilot do make it a little more rich, or give it a little crispness at 1/4 throttle? Quote
Gibby84 Posted September 29, 2020 Author Report Posted September 29, 2020 Just looking to pick someones brain on this. I can start it. But the Banshee just does not want to idle. I rebuilt the carbs and cleaned them. Want to try to ride up in Kalkaska Michigan elevation 1,033 Quote
Semir350 Posted November 26, 2020 Report Posted November 26, 2020 Carbs synced? Choke tube installed? Idle screws or tors?? Sent from my SM-G975U using Tapatalk Quote
375hp banshees Posted November 26, 2020 Report Posted November 26, 2020 Man thanks, i've been waiting two months to ride Quote
blsnelling Posted November 26, 2020 Report Posted November 26, 2020 I would install 27.5 pilots and set the air screws at 1 1/2-1 1/4. You might need to drop your needle 1 clip position to lean it out a bit in the mid-range. Quote
375hp banshees Posted November 26, 2020 Report Posted November 26, 2020 R u from flint too !!!Sent from my SM-A505U using Tapatalk Quote
blsnelling Posted November 27, 2020 Report Posted November 27, 2020 3 hours ago, 375hp banshees said: Or Ohio? I'm from Ohio, between Cincinnati and Dayton. Quote
