iTeach Posted September 12, 2020 Report Share Posted September 12, 2020 Hello, I accidentally pressed my front brake lever when there was no fluid inside. And it seems as if the “piston” is pushed all the way in, that thing inside the front master cylinder where the lever pushes against. Does this mean I need a new master? Or will it come back out after I bleed the brakes? Thank you. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted September 13, 2020 Report Share Posted September 13, 2020 You probably went in farther than it usually goes. They're typically spring loaded, it might un-stick but i'd try & pull it back out ( with fluid in reservoir)before pushing it in farther & when you bleed it, only go in1/2 way in each time, until it gets some psi built up.Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
