Spark plugs keep coming loose
You need to get that detonation under control or you will  destroy that motor.
I don't know what type of riding your doing but imo - 210# is to much compression and what I'd address first but there are other possible things that could add to your problem. To low an octane fuel, to much timing, lean jetting etc
  • Like 1
You need to verify the compression.
If it is that high u need different domes.
+10 is too much unless you got a lot of clues,correct fuel, correct squish, correct jetting/tune.
What brand compression tester
What’s ur elevation
Remove stator cover and look at the plate the stator is bolted to. You’ll see if it is adjustable.
The stock plate is cast metal.
A aftermarket plate is generally billet aluminum and Wher the case halves meet will have a mark with numbers for adjustment.
