Banshee870 Posted August 1, 2020 Report Posted August 1, 2020 OK guys I just bought a 2003 banshee, it only has a boost bottle Toomey t4 exhaust and kandn filter still has the airbox and airbox lid, now when I got it the tors had been removed and I had install the idle jets, It gets pretty hot pretty fast and the right exhaust will backfire a lil now the exhaust doesn't smoke a lot on the right no im pretty sure my crank seal is good. But say when u ride it u pull in the clutch she goes to die. got to give her gas to keep her going.. also the first night I put the idle screws in we got her idling perfect but the next day she went to the same thing wouldn't idle and wanted to die when u pulled in the clutch … I lost fellas please help Quote
Banshee870 Posted August 1, 2020 Author Report Posted August 1, 2020 Also fellas the left exhaust is blowing hotter than the right side it actually isn't even really hot at all , and if I remember correctly the left exhaust is getting hotter than the right Quote
kawa110 Posted August 1, 2020 Report Posted August 1, 2020 You need to start with a leak down test. Sent from my iPhone using Tapatalk Quote
