Reving out on its own
When i start it up its super reved up and doesnt idke down. Went through the reeds and bought a pair of lectron carbs and all looks perfect but am still having this problem. Almost afraid to even start it i dont want to damage it by it reving to the moon right off the bat.
Anyone know what can cause this? Im at my wits end with it
Sent from my SM-N975U using Tapatalk
Are the slides in the carbs correctly? Are the slides hanging up? Did you get the needles aligned with the jet when you installed the slides?
Everything is lined up and installed correctly but its still doing it. Did it with my old carbs as well
  • 1 month later...
Running to lean. Check the boots on your carbs, trace your throttle cable to make sure it isnt hung up. Pull air filters and make sure slides are down and synced. Thats basically the complete list of what you need to check. If its none of these things, its possessed and has ghosts in its blood, you should probably do cocaine about it.
