coleman66six Posted July 30, 2020 Report Share Posted July 30, 2020 At first when i pressure tested the engine it leaked at the bottom on the same piece, and i noticed that i was missing a gasket between there, so i put one in on each reed and then tested it, got rid of the leak on the bottom but now there is one on the top of each. How do I feel this and should I worry about it? Thanks. Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted July 30, 2020 Report Share Posted July 30, 2020 Small amount of yamabond should fix you up, have had luck with added second gasket on both side of cages. Less to clean off later Sent from my LG-H873 using Tapatalk Quote Link to comment Share on other sites More sharing options...
coleman66six Posted July 31, 2020 Author Report Share Posted July 31, 2020 Small amount of yamabond should fix you up, have had luck with added second gasket on both side of cages. Less to clean off later Sent from my LG-H873 using TapatalkWorked good and holds 7 psi for 7 minutes, thank you. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted July 31, 2020 Report Share Posted July 31, 2020 Worked good and holds 7 psi for 7 minutes, thank you. Sent from my iPhone using TapatalkGood stuff. Sent from my LG-H873 using Tapatalk Quote Link to comment Share on other sites More sharing options...
