Redline Racing Build
iTeach
Hello Banshee Community,
     I’m sending my engine to redline for a rebuild.  However, I’m not to sure the route I should go. Whether 4mil? Etc. I would like to run pump gas, and an OEM CDI. I’m flexible on the carbs. Also reliability is my first and last priority. I go to the trails often a lot of hills, therefore low end-mid power is important. Any suggestion and advice is welcomed. Thank you.
I was on the same fence until I did some math and compared price on going stock cyl 4 mil or using driveline Cylinder kit and I honestly Did the math I would rather just order the driveline kit and spend the extra money .Which isn’t a lot Of a difference ,if you need to port and bore and order new piston for your stock cylinder.im going to a driveline kit .For that reason i get a 421 cylinder kit for just about a bit more than reusing and restoring my stock cylinders.
whats ya budget
4mm stock cylinders are more reliable than stock
i ran one for years not an issue ... ever
mine had CPI's and PWK33s with 155psi comp as as solid
what pipes do you have ??
  • Thanks 1
10 minutes ago, GNR101 said:
whats ya budget
also cams good to deal with
im currently running a 10mm serval its had cases trenched and ported by cam
and im over in australia
  • 3 weeks later...
On 7/30/2020 at 8:15 AM, iTeach said:
I’m running FMF’s fattys. It looks I’ll prolly go with a stock ported cylinder 4mil. But keep the opinions running!!
as a trail or playing in the dunes a actually  preferred my FMFs over my cpis on my 4mm build... it ripped you arms off.. just didnt rev to the moon
