Need some help fine tuning my banshee build
Hey guys, I need some help with low end tuning on my shee. Well, I have a stock bore, ken o'Conner trail port, k&n power pods w/covers (airbox delete), boyesen power reeds (stock case), boost bottle, tors eleminator kit, stock carbs, 21 cc Vito's hemi cool head, Vito's red needles on 2nd clip, 310 mains, and 37.5 pilots.           I started out rich with 340 mains, and 30 pilots, center clip. Since then I'm dialed in somewhat at 310 mains, 37.5 pilots and 2nd clip. I believe I need to go up to a 40 pilot or bigger since my air screws are about 1 turn out. Right now it's running good, but a little fat. Bottom end is poor until it hits pipe. It does not run hot at all or foul plugs. Plug chops on top end look good. I'm at about 1000ft elevation, temps outside about 75. And help would be great, thanks guys!!
  • 2 weeks later...
I have 4mil banshee, 795 Wiseco ,FMF pipes, 34 mm PJ carb ,Main Jet 152 ,pilot jet 55, air screw 1 and 1/2 turns out .110 race fuel ,castor 927 . At 32:1 I have oil coming out of my exhaust I was wondering if it would hurt to 40:1 ? Or do I need to rejet .any help would be awesome thanks guys
If it’s just the right pipe I would say crank seal,left then carb adjustment. If it’s both then:
First thing I would check is see if you really need 110 octane. If you don’t the fuel will not burn right and could cause it.
 Is it idling/running good without any spots of hesitation?
Edited by Burt Reynolds
