1999YamahaBanahee Posted June 12, 2020 Report Posted June 12, 2020 So I'm building my 421 serval this weekend. Curious if anyone could tell me if I should be close with jetting. Dont want to damage a new motor. I have a 421 serval, shearer small bore inframes, 35 pwk, vf4 reeds, +4 timing, 23cc domes running 110 octane. I ride about 60-80 degrees at 1300ft. I was thinking 155 mains with 48 pilots and cel needle middle clip. Any info would be great. Quote
machinegunbanshee Posted July 19, 2020 Report Posted July 19, 2020 I cant remember what I got as far as pilots and needles. But I just installed 165 mains. Your setup is identical to mine. Im northern Wisconsin and 85 degrees Quote
machinegunbanshee Posted July 19, 2020 Report Posted July 19, 2020 ill let you know more if I get a chance to check pilots and needles Quote
1999YamahaBanahee Posted October 16, 2020 Author Report Posted October 16, 2020 You ever figure out your jetting? There's no one really around me to help with the banshee as no one really has them around me. Let alone build one. Now im running 152 mains, 50 pilot 2 turns out with cel middle clip. Runs good but feel like it could be better. I have 35mm air strikers which is why our jetting different. I was unaware they were air strikers when I bought them. Its also very hard to cold start. Quote
1999YamahaBanahee Posted October 17, 2020 Author Report Posted October 17, 2020 If I ride easier through the woods then lay in it, it will cut out for a brief second then take off. And if im a gear high and give it wot it will cut up a few times then smoothly go into the power band. I ordered a bunch of plugs and a bit to do plug chops. I heard that the cut up is something air strikers are known for. Im just trying to make it work before I go out and buy new carbs. Quote
gusto Posted October 18, 2020 Report Posted October 18, 2020 No expert with those carbs, if your close on the jetting only adjust the slide at this point. That will tell you if your going to need more or less jetting Quote
1999YamahaBanahee Posted October 18, 2020 Author Report Posted October 18, 2020 Slides are synced and set properly with the sync tool. Just waiting for work to finally give me a day off to start doing chops. Quote
