Eric_C1 Posted June 5, 2020 Report Posted June 5, 2020 I have a 4mil serval cub and they seem like the perfect pipes for where I ride, just wondering if anyone has experience with them and if they would recommend them or not, can't find too much info on them Quote
ginger Posted June 5, 2020 Report Posted June 5, 2020 i have them on my stock cylinder 4mil stroker, and love them, best comparison is they are like a CPI pipe, but start pulling at a lower RPM and fall off before a cpi will. almost the same curve, just shifted to lower RPM. I had to add teeth to the front sprocket because i would top out in my fields so fast. Quote
gusto Posted June 5, 2020 Report Posted June 5, 2020 check out my dyno graph in the dyno section. I tested them on the same engine, the description above is close. Quote
Eric_C1 Posted June 6, 2020 Author Report Posted June 6, 2020 13 hours ago, gusto said: check out my dyno graph in the dyno section. I tested them on the same engine, the description above is close. Think i'm gonna try them out, thanks. 😎 Quote
