Vf4 reeds
8 hours ago, 101questions said:
I’m running a 421 With 35pwk ,shearer exhaust small bore, 68mm cylinders, big bore 9 degree 21cc domes what you think I should jet it to? 600ft above sea level
Just start at 175 and 55 and work from there.
Envoyé de mon SM-G965W en utilisant Tapatalk
im running a very similar setup and at 75* F, same elevation im at 155M, 45P, and a CEL needle. starting rich and dropping down at increments help a lot with learning how the jet changes affect the response and overall behavior of the setup.
