Wiring for light bar
If that light bar truly needs a relay, you don't have a big enough stator to run it if you still have the stock stator. If it is a LED bar, you probably don't need the relay, but you should be floating the stator ground, adding a rectifier( a DC conversion). LEDs don't last long when ran on AC power. You should read up on the Banshee electrical system and the threads about adding LED lights.
