Aftermarket Headlight Options
What's up HQ, been a while since this topic has been covered. Any recommendations on running aftermarket headlights? I see cascade innovations sells a kit, picture attached. Looking to add a set of lights on my 521. Anyone run these ones here? Thanks a lot.
Sent from my SM-G950U using Tapatalk
The cleanest way to run LED lights is to separate ignition power and lights power by floating the ground, then convert the lights power to dc with a cheap (8$), 125Watts,4 wires, ac/dc converter/rectifier/regulator.
https://www.jlengineering.org/banshee-stator-dc-convers.html
Envoyé de mon SM-G965W en utilisant Tapatalk
Sweet, I'll be doing this. Would you happen to know the output voltage of the rectifier/regulator that you posted? OEM is 12V, is the one you posted the same?
Yes, output is 12V dc.
https://www.ebay.com/itm/292689887133
Thanks Claude. Wife is about to have baby #2 any second now, so it will be a little bit before I can do this. I will update this thread when I can. You run OEM headlights on your SS, correct? Thought I remembered seeing a pic of your bike with stock headlights.
i have those here. they look like the original ones, but they aren't :)
i realised that, after i ordered a new pair of "original" bulbs for the banshee. but they were way to small.
you can get in much bigger bulbs in these headlights. i prefer the original look^^
I use this for rear lights: https://www.ebay.com/itm/264443106178
And this for front: https://www.ebay.com/itm/183695899713
Cheap stuff, i bought 4, 4 years ago, and only replaced one this season, so i still have one spaire ;-)
Recently I've seen a Baja racer's banshee with 2x Baja Design Squadron's LED's in place of the stockers with a OnX6 6 bulb amber clamped to the handle bars. You'll need some wattage to run that setup though.
Cheap stuff, i bought 4, 4 years ago, and only replaced one this season, so i still have one spaire 😉
So when using the rectifier the lights wont dim like they would on the AC Circuit, but hold the same brightness through all RPM ranges of the engine?
Do you use this rectifier on your bike?
Edited by PaymentPlan
Diming is another thing. You can solve the "problem" doing 2 things or three.
1- putting a batt.
2- putting a capacitor who will act like a batt.
3- man up, and dont care about diming under 1000rpm....
I chosed the 3th option ;'l
1- putting a batt.
Ok, so what's the advantage of running the rectifier then? I would think that would solve the dimming
1- putting a batt.
Hahahah the third option sounds like reasonable option
Sent from my VOG-L29 using Tapatalk
