fervaldez Posted April 22, 2020 Report Share Posted April 22, 2020 (edited) Hello everyone, I tell you what happens with my Banshee, one day I realized that the cylinder on the right side stopped working, the mechanic already checked it and I commented the following. It is a 2003 banshee the carburettors are the factory only they removed the Tors system, it has compression, it has a spark, it is assumed that the carburettors are in good condition the mechanic revised them on various occasions, we have already changed the stator, the coil, the cdi And now I don't know what else to do, I need your help. Edited April 22, 2020 by fervaldez Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 22, 2020 Report Share Posted April 22, 2020 Were new elec. Parts oem? Easiest check: Swap wires left to right & see if it changes sides (2 check compression done) 3 leakdown test Did you do anything just before it started this problem? Quote Link to comment Share on other sites More sharing options...
fervaldez Posted April 24, 2020 Author Report Share Posted April 24, 2020 Yes the electrical parts were new oem Replace the cables and the fault continues in the same cylinder. They have checked for leaks and nothing. I did nothing, the last thing was to take it to the mechanic to a service, it worked well for a couple of days and then this was the last thing. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 24, 2020 Report Share Posted April 24, 2020 It went in for service only & problem started days later? What does it have for air filter setup? You verified both slides are moving & in sync?""it is assumed that the carburettors are in good condition the mechanic revised them on various occasions"" when was the last various occasion? i'd start thereDoes it not fire @ all or just at certain rpm's? Try & pull one wire off while running (@low & again @ high rpms) & see if you can tell a difference. Start with the dead side then put back on & try good side.Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 24, 2020 Report Share Posted April 24, 2020 Replaced cables or swapped side to side?Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
