ClaudeMachining Posted April 15, 2020 Report Share Posted April 15, 2020 I think i danaged the thread of my flywheel when it came off last year. I cant screw in the M27 puller. Any trick??? Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 15, 2020 Report Share Posted April 15, 2020 Pullers are cheap, work it back n forth with ALOT of anti seize, with a couple of pullers to keep threads good? After cleaning up as good as you can with a pick? Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
SKEETER Posted April 15, 2020 Report Share Posted April 15, 2020 Weld that bitch on Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 15, 2020 Report Share Posted April 15, 2020 Left hand thread 1 Quote Link to comment Share on other sites More sharing options...
97Screamer Posted April 15, 2020 Report Share Posted April 15, 2020 Those threads don't look so bad. Assume you know its left hand threads and thats not the problem I'd buy a thread file and clean them up. 1 Quote Link to comment Share on other sites More sharing options...
SKEETER Posted April 15, 2020 Report Share Posted April 15, 2020 Seems complicated for an engineer Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted April 15, 2020 Author Report Share Posted April 15, 2020 Seems complicated for an engineerAsking for trick is not a weakness, unless you think you know it all.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted April 15, 2020 Author Report Share Posted April 15, 2020 Those threads don't look so bad. Assume you know its left hand threads and thats not the problem I'd buy a thread file and clean them up. It look like the first 2-3 threads on the flywheel are done...That suck, i wanted to float my ground like i did on the trx.I guess i'll stay AC one more season lol!!Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted April 15, 2020 Author Report Share Posted April 15, 2020 Just to be sure, i checked on the trx flywheel, the puller is ok.Fuck.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 15, 2020 Report Share Posted April 15, 2020 Get in there with a pick or utility blade & straighten them out now, while you have time you know somethings gonna come up/ happen & your gonna need to remove it in a pinch & cuss your self laterSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted April 15, 2020 Author Report Share Posted April 15, 2020 Get in there with a pick or utility blade & straighten them out now, while you have time you know somethings gonna come up/ happen & your gonna need to remove it in a pinch & cuss your self laterSent from my SM-A505U using TapatalkI know....Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
Keno Posted April 15, 2020 Report Share Posted April 15, 2020 Make a left handed tap with your machining skillz Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted April 15, 2020 Author Report Share Posted April 15, 2020 13 minutes ago, Keno said: Make a left handed tap with your machining skillz Very good idea, but no school t'll at least 1 more month Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 15, 2020 Report Share Posted April 15, 2020 I cut reliefs with cut off wheel in a second puller to make a thread chaser. But I'm no engineer. 1 Quote Link to comment Share on other sites More sharing options...
