Ok, finally have some answers instead of questions. Did multiple plug chops today from 148-162. Not much difference in the width of the smoke ring. In the last pull a happened to look down and the fuel line was completely empty . Like like I'm in the market for a pingle valve. At least I'm making progress.
Sent from my SM-G965U using Tapatalk
Does anyone have the bolt hole center dimensions for the banshee prtcock? I think it's the same flange as mine, I just want to make sure.
If the soot ring isn’t growing I would guess it is lean in the mid range color wise I like the 162 plugs any chance you can lift the needle 1 notch (lower the clip) with the 162  then do a 20 min ride no more than 1/2 throttle. Please post pick of 20 min plug whole then chopped only need to chop 1 plug for this test. Do you have a laser thermometer after your run take a temp of the cylinders and one of the pipe on each side about 3 inches off the jug. Thanks
Ok, finally got to spend some time with the bike today. Did plug chops with 152 and 148, wanted to get everyone's opinion.
Also did a 30 min ride with a brand new plug, no more than half throttle. Left cylinder head temp was 211 at the outside of the head, right was 210. Pipe temp 3" from the cylinder was 266 left, 264 right.
Thanks in advance everyone!1196843c4f7f9fe8c795efe9c4954687.jpgfe0dd92fd3d71ceb5f733e4c6d69e45f.jpgfe4d863af16f06a7e3a03407a093d9f2.jpgdeeaf86ce7aec3ce0da372e72ead3c05.jpg4972b86ce49b801abc2e5bd8ec9f3d3d.jpg1d68ad9f71e29f048a5d9ce0817f5e67.jpg5b8546065f1387eb794e364930ee070b.jpgc0a2e4f3ed272e63625fec52429a4e2e.jpgdb6ec5f7505f3b9371f6b6986bde56d9.jpg
