Big Mike NY Posted April 7, 2020 Report Share Posted April 7, 2020 Whats up homies! Hope you all and your families are safe and healthy l! I put pro taper TE CR high bend bars and pro taper clutch perch on the banshee this weekend. The bars fit perfectly, the oem ignition switch the clutch perch and the oem throttle all fit and line up as they should.The big issue is with the front brake reservoir and handle. The mount for the front brake is on the down slope of the handle bar which is causing brake lever to aim upward about 1/2” above the grip/handle bar.I have the same exact setup on my Honda TRX 250R (same bars and clutch perch) and everything works flawlessly.. What needs to be done to correct this condition? Here are some photos of what I’m talking about as well as a photo of my TRX Is setup with the same bars.. Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 7, 2020 Author Report Share Posted April 7, 2020 (edited) Whats up homies! Hope you all and your families are safe and healthy l! I put pro taper TE CR high bend bars and pro taper clutch perch on the banshee this weekend. The bars fit perfectly, the oem ignition switch the clutch perch and the oem throttle all fit and line up as they should.The big issue is with the front brake reservoir and handle. The mount for the front brake is on the down slope of the handle bar which is causing brake lever to aim upward about 1/2” above the grip/handle bar.I have the same exact setup on my Honda TRX 250R (same bars and clutch perch) and everything works flawlessly.. What needs to be done to correct this condition? Here are some photos of what I’m talking about as well as a photo of my TRX Is setup with the same bars.. **EDITED ; I didn't realize my text color in my original post was black so the only way I figured out how to fix that was to reply to myself and change the color of the text so its easier to read. So anyone know what the hell the issue is here with the brake lever and master cylinder? Edited April 7, 2020 by Big Mike NY Quote Link to comment Share on other sites More sharing options...
kawa110 Posted April 7, 2020 Report Share Posted April 7, 2020 Looks like the billet lock on grip pc is preventing the throttle from Being snug, thus keeping the resi down on the “bar bend”Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted April 7, 2020 Report Share Posted April 7, 2020 Different grip or Maybe a Honda throttle housing Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 7, 2020 Author Report Share Posted April 7, 2020 EXACTLY! I run the ODI 120mm (not the 130mm) grips are there any other ATV grips that are narrower thanj that? I only need to move the master cylinder just a tad.. I emailed Pro Taper because they are not taking calls because of the virus. Lets see if they get back to me?? Fucking frustrating! Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 7, 2020 Author Report Share Posted April 7, 2020 Would a shorter lever work? Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 8, 2020 Author Report Share Posted April 8, 2020 I reached out to Pro Taper.. I told them exactly what I posted here with pics and they replied back... “ Mike, Send me over your address and I will send you a different set to try. At no charge of course. I understand the situation of the markings and I assume they would not take them back. Please supply me a shipping address. I will send you the CR Mid bars as they have about 10 Millimeters more of control space. Thank you,” Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 8, 2020 Author Report Share Posted April 8, 2020 How awesome is that!!! 😎 1 Quote Link to comment Share on other sites More sharing options...
BANSHEE CHAOS Posted April 10, 2020 Report Share Posted April 10, 2020 (edited) They replied back nothing or in black font? 😁 I managed to read it. That is extremely deluxe of them! 👍🏻 Edited April 10, 2020 by BANSHEE CHAOS 1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 11, 2020 Report Share Posted April 11, 2020 Nice! If that doesbr work, a honda thumb throttle is more narrow. And more comfortable Sent from my SM-G970U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 11, 2020 Author Report Share Posted April 11, 2020 Thanks which Honda throttle? TRX 250R, 450R, 400EX? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted April 11, 2020 Report Share Posted April 11, 2020 Honda's throttle got a cam inside, they are softer.Envoyé de mon SM-G965W en utilisant Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted April 11, 2020 Report Share Posted April 11, 2020 Different grip or Maybe a Honda throttle housing Sent from my iPhone using TapatalkHonda 400ex throttle(pretty much all Honda the same If I remember right) Trx90 thumb lever. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted April 11, 2020 Author Report Share Posted April 11, 2020 Cool Bros! I didn’t know thank you for that information I’m going to change over to the Honda throttle even though the CR mid bends fit all my Yamaha controls now. The Yamaha throttle is so resistant to push and I put a brand new throttle cable on.. With the Honda throttle what kind of throttle cable is required? As I type this... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted April 11, 2020 Report Share Posted April 11, 2020 Same cable. Easy swap Sent from my SM-G970U using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
