Younginwithabanshee99 Posted April 6, 2020 Report Posted April 6, 2020 Hey Guy, my cousin told me putting this 20$ adjustable timing cover on his banshee made a world of difference. Says it brought out a crazy amount of power. Do they really make that big of a difference? Are they reliable or are the just junk that's going to break? Or Should I put it on my list of parts to order? Let me know your thoughts thanks Quote
Stingray Posted April 6, 2020 Report Posted April 6, 2020 Yes they can make a lot of power beware of cast ones I had one come apart and destroy the stator. Now I run a billet one. Unless you run race fuel I would run 3 or 4 deg max 91 to 93 octane. If it back it down or run better fuel it will KILL an engine quickley. If you run race fuel I start at 6 deg and alky 10 or more depending on compression Quote
Younginwithabanshee99 Posted April 6, 2020 Author Report Posted April 6, 2020 14 hours ago, Stingray said: Yes they can make a lot of power beware of cast ones I had one come apart and destroy the stator. Now I run a billet one. Unless you run race fuel I would run 3 or 4 deg max 91 to 93 octane. If it back it down or run better fuel it will KILL an engine quickley. If you run race fuel I start at 6 deg and alky 10 or more depending on compression I have always ran rec fuel and valvoline 2 stroke oil at 32:1 Quote
Stingray Posted April 7, 2020 Report Posted April 7, 2020 I run race fuel 40 to 1 with 927 castor 10 deg advance cool head with 15 cc domes and 68.5 mm big bore Pistons. I do plug chop after every mod and show no pinging (aluminum transfer at base of plug). If everything is sealed no leaks and jetted correctly you should be able to run 4 deg all day long. A plug chop will tell you everything you want to know about your timing and jetting. Quote
Stingray Posted April 7, 2020 Report Posted April 7, 2020 Best power gains are 1 port job 2 compression 3 pipe 4 timing 5 carbs Quote
Younginwithabanshee99 Posted April 7, 2020 Author Report Posted April 7, 2020 12 minutes ago, Stingray said: I run race fuel 40 to 1 with 927 castor 10 deg advance cool head with 15 cc domes and 68.5 mm big bore Pistons. I do plug chop after every mod and show no pinging (aluminum transfer at base of plug). If everything is sealed no leaks and jetted correctly you should be able to run 4 deg all day long. A plug chop will tell you everything you want to know about your timing and jetting. So I just ordered a timing cover. Is stock at 0 deg? Quote
Stingray Posted April 7, 2020 Report Posted April 7, 2020 Yes it will have + and - 10 deg with 0 in the middle and the pointer is the split in the case Quote
n2otoofast4u Posted April 7, 2020 Report Posted April 7, 2020 Best power gains are 1 port job 2 compression 3 pipe 4 timing 5 carbsLOL Quote
muggzy Posted April 9, 2020 Report Posted April 9, 2020 Hey, can anyone with experience adding an adjustable timing plate tell me of the power gains are across the board, lo end or high end?If it's across the board, is it bigger on the low end? Thanks in advanceMods;Ported (unknown details)Pwk-28 carbsTrinity stage 4 pipesOpen airbox w/K&N filter20cc domes on Pro Design CoolheadSent from my Pixel XL using Tapatalk Quote
ClaudeMachining Posted April 9, 2020 Report Posted April 9, 2020 It add low end grunt. Any billet one will do the job.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Younginwithabanshee99 Posted April 9, 2020 Author Report Posted April 9, 2020 1 minute ago, ClaudeMachining said: It add low end grunt. Any billet one will do the job. Envoyé de mon SM-G965W en utilisant Tapatalk Is this going to affect jetting at all? I assume it will Quote
kawa110 Posted April 9, 2020 Report Posted April 9, 2020 The plate is worth every penny! You will need a flywheel puller as well. Sent from my iPhone using Tapatalk Quote
registered user Posted April 9, 2020 Report Posted April 9, 2020 sometime thE flywhel get stuck. jus cut it with a torch Quote
ClaudeMachining Posted April 9, 2020 Report Posted April 9, 2020 3 hours ago, Younginwithabanshee99 said: Is this going to affect jetting at all? I assume it will Probably not, you can put one number bigger for a start to be safe Quote
