SparkMarc Posted March 29, 2020 Report Share Posted March 29, 2020 So I have a 2000 banshee that runs great on the left side but the right side seems to run fat. The plug is always really dark and has some oil usually on it pretty much fouls out. It also smoke more and has weak exhaust pressure on the right side . the left side is perfect. it’s bored Like 60 over has about 6 hours on the top end has Boisen reeds,new fmfs , jetting is 260 pilots 30 and elevation about 80-100 feet above sea level has the vitos machined air box mod that bolts to original air box with k&n style filter has tors deleted carbs from vitos as well. Compression in left cylinder 135 compression in right cylinder 130-135 as well . Passes a leak down test. Everything is in sync what is the problem any advice please been going crazy trying to figure it out Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 29, 2020 Report Share Posted March 29, 2020 Have you swapped plug wires side to side? Tho not common and could be a carb issue, might need to jet carbs differently from each otherSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 29, 2020 Report Share Posted March 29, 2020 Just saw you said tors deleted carbs from vitos ...meaning bought kit & did delete or bought his carbs? If carbs, make sure they are not knock off's. if so you'll probably never get them right! Quote Link to comment Share on other sites More sharing options...
SparkMarc Posted March 29, 2020 Author Report Share Posted March 29, 2020 I’ve tried swapping wires around still no difference and how do u exactly tell if there genuine because yes I bought them with the tors deleted already from him Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 29, 2020 Report Share Posted March 29, 2020 Usually price , but ray will charge you close to full price & say they are real so...I've heard no serial numbers on flat spot above bowls and vent hoses that come with them, are more clear than dark pink, like genuine Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
SparkMarc Posted March 29, 2020 Author Report Share Posted March 29, 2020 I have another set and there identical just diff numbers so I’m pretty sure there genuine Quote Link to comment Share on other sites More sharing options...
SparkMarc Posted March 29, 2020 Author Report Share Posted March 29, 2020 Could jetting the carbs differently work I was thinking about it but wasn’t sure. Ever seen any one do that ? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 29, 2020 Report Share Posted March 29, 2020 Yes, they are basically 2 separate engines. Are your other carbs good, swap out right side carbSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
SparkMarc Posted March 29, 2020 Author Report Share Posted March 29, 2020 No they are messed up otherwise I would . I switched around the reeds and adjusted the float level and it seemed to have made a difference but now it cuts out a lil around 4-6 gear Quote Link to comment Share on other sites More sharing options...
