jack vo Posted March 27, 2020 Report Share Posted March 27, 2020 Will a stock bore banshee with Decked head Vf4s Shearer pipes Dune port See a huge improvement with 34mm carbs and a timing plate? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted March 27, 2020 Report Share Posted March 27, 2020 No , but timing will help ( provided its tuned properly) Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted March 28, 2020 Report Share Posted March 28, 2020 More timing = more grunt.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 28, 2020 Report Share Posted March 28, 2020 You would see more result with the timing then the carbs. If you want bigger carbs on that, go to 35’s if you want more top end charge. If you want more low end grunt, keep the stock carbs or maybe switch to 28’s-33’s. Going bigger on carbs, you would definitely lose a bit of that low end snap feeling. Quote Link to comment Share on other sites More sharing options...
jack vo Posted March 29, 2020 Author Report Share Posted March 29, 2020 Thx Quote Link to comment Share on other sites More sharing options...
