Jaime Posted March 23, 2020 Report Share Posted March 23, 2020 So my banshee has been leaking oil coming out of my vent hose and my compression has gotten weaker as well. Can it also be the radiator? Quote Link to comment Share on other sites More sharing options...
97Screamer Posted March 23, 2020 Report Share Posted March 23, 2020 No, your crank seal is shot. Time for a rebuild.Sent from my HTC One M9 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
wlkinlivinlegend Posted March 24, 2020 Report Share Posted March 24, 2020 What would that mean would I have to rebuild the whole crankshaft or just the seal? Thx for helping. 19 hours ago, 97Screamer said: No, your crank seal is shot. Time for a rebuild. Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
wlkinlivinlegend Posted March 24, 2020 Report Share Posted March 24, 2020 I have two acc sorry. Quote Link to comment Share on other sites More sharing options...
97Screamer Posted March 24, 2020 Report Share Posted March 24, 2020 Just the seal but your whole motor needs to come apart to change it so you'll need to inspect everything and replace as necessary. Quote Link to comment Share on other sites More sharing options...
wlkinlivinlegend Posted March 25, 2020 Report Share Posted March 25, 2020 3 hours ago, 97Screamer said: Just the seal but your whole motor needs to come apart to change it so you'll need to inspect everything and replace as necessary. How much would that be in total to replace. Thank you. Quote Link to comment Share on other sites More sharing options...
SKEETER Posted March 25, 2020 Report Share Posted March 25, 2020 Call local engine builder. If your doing it yourself, the clymer manual will cost more than the seal. 1 Quote Link to comment Share on other sites More sharing options...
wlkinlivinlegend Posted March 25, 2020 Report Share Posted March 25, 2020 Should I just get a hot rod crank and if I do, do I have to do anything to the engine/carbs/pistons Quote Link to comment Share on other sites More sharing options...
97Screamer Posted March 25, 2020 Report Share Posted March 25, 2020 The seal is about $10. To have someone install it is probably $300-500. You should inspect everything and replace what's necessary. If you have a quality crank in good condition keep it, if not replace it. You can change cranks without needing to change anything else provided you're swapping the same stroke. Quote Link to comment Share on other sites More sharing options...
