Deets Posted April 18, 2020 Author Report Share Posted April 18, 2020 They both had to go down and in on mine. Definitely need pipe wrap. mine haven’t had any issue coming loose after two tanks so far. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted May 30, 2020 Report Share Posted May 30, 2020 Still not a fan of how they rub on frame. I’m looking for smallerSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
2Smoker350 Posted May 31, 2020 Report Share Posted May 31, 2020 Maybe you should look at the Toomey 2:1 filter setup. I was having the same problems. The pod filters were either rubbing on the frame or rubbing on the stinger tubes and causing them to melt both the k&n filter and outerwear during warm up. 1 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted May 31, 2020 Report Share Posted May 31, 2020 Right on! Thnx for idea. I’d rather run pods. But will consider the 2 into one. I really don’t want melted stuff. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted May 31, 2020 Report Share Posted May 31, 2020 Maybe you should look at the Toomey 2:1 filter setup. I was having the same problems. The pod filters were either rubbing on the frame or rubbing on the stinger tubes and causing them to melt both the k&n filter and outerwear during warm up. Can you get a pic of your set up?Sent from my LG-H873 using Tapatalk Quote Link to comment Share on other sites More sharing options...
