Uni Pod filter's clearance with SLP exhaust
Those aren’t angled pods I guess? Usually you can angle the filters down. I think if your insulation is working you’ll be fine
The filters are the 15 degree angle one. I have them pointed down and in a bit. There's about 1/4" space with rad hose.
Sent from my LG-H873 using Tapatalk
I had the same issue with a set of CPI’s. I swapped the billet intakes for a set of UPPs, worked like a charm. The UPP intakes pulled the carbs down which gave plenty of room for the filters. I had a thread about this but can’t seem to locate it...
