Dmac68 Posted March 12, 2020 Author Report Posted March 12, 2020 Take your stator cover off. Take pic of timing plate. I pulled the stator cover off but you can’t really see the timing plate very well. Do I need to pull the flywheel ? Sent from my iPhone using Tapatalk Quote
alcoholbanshee Posted March 12, 2020 Report Posted March 12, 2020 (edited) Snap a pic focusing on the right side of the flywheel, just above the pick up coil. Edited March 12, 2020 by alcoholbanshee Quote
Dmac68 Posted March 12, 2020 Author Report Posted March 12, 2020 Snap a pic focusing on the right side of the flywheel, just above the pick up coil.Sent from my iPhone using Tapatalk Quote
ClaudeMachining Posted March 12, 2020 Report Posted March 12, 2020 No advance.Now squish and uccr tests.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
alcoholbanshee Posted March 12, 2020 Report Posted March 12, 2020 18 minutes ago, ClaudeMachining said: No advance. Now squish and uccr tests. Envoyé de mon SM-G965W en utilisant Tapatalk Yup, I wanna know what the squish is and exactly what octane fuel you were using when it was backing plugs out. My guess is going to be poorly designed domes. I am assuming these are trinity domes, and that does not give me the warm fuzzies. Quote
ClaudeMachining Posted March 12, 2020 Report Posted March 12, 2020 Yup, I wanna know what the squish is and exactly what octane fuel you were using when it was backing plugs out. My guess is going to be poorly designed domes. I am assuming these are trinity domes, and that does not give me the warm fuzzies.Yes, trinity domes doesnt have a good rep.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Dmac68 Posted March 12, 2020 Author Report Posted March 12, 2020 Yup, I wanna know what the squish is and exactly what octane fuel you were using when it was backing plugs out. My guess is going to be poorly designed domes. I am assuming these are trinity domes, and that does not give me the warm fuzzies.91 octane and yes it’s a trinity cool head with trinity domes. how do I perform the squish test with the engine on the bike ? Sent from my iPhone using Tapatalk Quote
alcoholbanshee Posted March 12, 2020 Report Posted March 12, 2020 Do a search on how to do squish. It is super easy to do and all you will need is a couple pieces of solder and a good measuring device. I dont feel like typing a small novel on a phone......sorry lazy 1 Quote
trickedcarbine Posted March 28, 2020 Report Posted March 28, 2020 I’ve gone through a few trinity motors with that same set up. At 160 psi with porting, the actual compression ratio will be a bit on the high side for sure. So you will definitely need to give it race fuel to keep the plugs from backing out. A 9 range plug may also help. Verify your stroke for sure stock is 54mm, 4mil Stroker is 58mm. Don’t be close, be sure Also, if you’re doing a 2/1 carb on a motor that size, make sure to have an upgraded larger single petcock, gutted check ball on gas cap, and a billit bowl on the carb. As far as squish test, you tube some of the South Texas Banshee stuff. He has video how to’s. You can also Google a guy that used to run a blog for banshees and blasters called MacDizzy. He used to put a lot of detail out on how to do all of that. Base gaskets play a role in all of this. Quote
SKEETER Posted March 28, 2020 Report Posted March 28, 2020 6 hours ago, ClaudeMachining said: UCCR ftw!! You spelled MURICA incorrectly ~ Quote
Dmac68 Posted March 29, 2020 Author Report Posted March 29, 2020 I’ve gone through a few trinity motors with that same set up. At 160 psi with porting, the actual compression ratio will be a bit on the high side for sure. So you will definitely need to give it race fuel to keep the plugs from backing out. A 9 range plug may also help. Verify your stroke for sure stock is 54mm, 4mil Stroker is 58mm. Don’t be close, be sure Also, if you’re doing a 2/1 carb on a motor that size, make sure to have an upgraded larger single petcock, gutted check ball on gas cap, and a billit bowl on the carb. As far as squish test, you tube some of the South Texas Banshee stuff. He has video how to’s. You can also Google a guy that used to run a blog for banshees and blasters called MacDizzy. He used to put a lot of detail out on how to do all of that. Base gaskets play a role in all of this. Thank you for the info ! What do you mean by 9 range plug ? Do you have a part number you would recommend ? Also what fuel ratio / mix would you suggest trying ? I will look up the test and get that done soon ! Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted April 17, 2020 Report Posted April 17, 2020 On 3/29/2020 at 3:39 PM, Dmac68 said: Thank you for the info ! What do you mean by 9 range plug ? Do you have a part number you would recommend ? Also what fuel ratio / mix would you suggest trying ? I will look up the test and get that done soon ! Sent from my iPhone using Tapatalk 32:1 Blendzall. If you don’t have Blendzall, find any other performance castor bean oil. Castor927 is a pretty good one. Mix with fresh 110. If you’re buying from the Sunoco gas pump, make sure it’s a place with high turnover so the fuel is fresh. 9 range plug is just the heat range on plugs. Typically guys have an 8 heat range plug in them like B8es or BR8es. A 9 range plug is a cooler burning plug. Quote
