I had that gauge laying around and figured I probably shouldn’t trust it. I will get a better one tomorrow and check again. I did notice the left hand side cylinder looked wet vs. right side being dry when I checking this stuff. What could be causing that? Head gasket leak ?
Okay I got another compression gauge and it was a huge difference the photos are attached. I also forgot to add I have black fluid coming from the exhaust. Raw fuel/oil 5dcd7b8d29cca3c5c8b90240fc798185.jpg
  On 3/11/2020 at 12:56 AM, SKEETER said:
Your good.
Compression wise ? I also noticed the spark plugs bad out when riding. The left is worse than the right . Would that be related ?
  On 3/11/2020 at 12:44 PM, alcoholbanshee said:
Not enough fuel, not high enough octane fuel, too much timing, poor dome design among others...
Thank you ! It’s a 2 into 1 carb setup and I am just running normal fuel with Klotz . What are your recommendations for this setup fuel mix wise ?
  On 3/11/2020 at 2:37 PM, alcoholbanshee said:
I would run at least 93 octane with that compression.  Do you know what your timing is. That would be an important number to know
I do not. Is there a way I can check that ?
  On 3/2/2020 at 7:34 PM, SKEETER said:
A micrometer with extendable measuring probe , find tdc, zero it out, go to bdc, and measure.      The cheap compression testers can read false.  Buy the best you can afford.  Orileys has 1 for 46$  I've tested with same results as a snap on.
First pic: Micrometer
Second pic: Electronic Caliper.
You need a Caliper, not a micrometer.026479d76528eca0f83c06723f120bde.jpgeb7c111933ab3b17034319096baf1f05.jpg
Envoyé de mon SM-G965W en utilisant Tapatalk
If you want to be sure, do a UCCR test. It's easy, all you need is a syringe of about 50cc.
Static compression wont tell everything.
Do a squish test too.
 https://youtu.be/ajCE1HRWaAE
