Gotti94 Posted February 24, 2020 Report Posted February 24, 2020 I’m heading out this weekend to have my shee put on a dyno, I have made some changes to my shee what kind of HP you think my shee will make? MODS: 68 stock cylinder Dune port 4mil crank 38mm keihin carbs +4 timing c12 race fuel vforce 4 reeds lock up clutch Clutch pusher pancake bearing por design cool head small bore shear pipes I think she will make about 85HP Quote
alcoholbanshee Posted February 24, 2020 Report Posted February 24, 2020 I don't know. That "por design" head will hold you back I think. 1 Quote
ClaudeMachining Posted February 24, 2020 Report Posted February 24, 2020 75hp.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Gotti94 Posted February 24, 2020 Author Report Posted February 24, 2020 1 hour ago, alcoholbanshee said: I don't know. That "por design" head will hold you back I think. Why do you think that? Quote
SKEETER Posted February 24, 2020 Report Posted February 24, 2020 Who resleeved your stock cyls ? Quote
Deets Posted February 24, 2020 Report Posted February 24, 2020 Can you take the sleeves out and just plate the stock cylinders? Quote
gusto Posted February 25, 2020 Report Posted February 25, 2020 Curious about your cylinders at 68mm. Where did you buy them? im goi g to say 77 hp Quote
Gotti94 Posted February 25, 2020 Author Report Posted February 25, 2020 1 hour ago, gusto said: Curious about your cylinders at 68mm. Where did you buy them? im goi g to say 77 hp Southern built performance Quote
Duke 2 Stroke Posted February 25, 2020 Report Posted February 25, 2020 8 minutes ago, SKEETER said: Knowing that, I'd say 58hp 🤭 Quote
Gotti94 Posted February 25, 2020 Author Report Posted February 25, 2020 9 hours ago, SKEETER said: Knowing that, I'd say 58hp he put in work local builder out of Miami . Quote
trickedcarbine Posted February 25, 2020 Report Posted February 25, 2020 Upper 70’s hp. The big bore sleeves in a stock cylinder just don’t allow much transfer volume to make much more power with out welding. 1 Quote
