vanillaGorilla33 Posted February 1, 2020 Report Share Posted February 1, 2020 What’s up everybody? I’m a long time lurker that can usually get everything figured out with the search feature but I’ve hit a wall, hopefully somebody can help me. I’ve got a 7mm, drag ported stock cylinder I’ve been building. It has 18cc domes, 0.051 squish, +5 timing, and runs on straight 110. The plugs were gapped at .031 to start and after doing the first heat cycle, both plug gaps were around .075. I’ve heard of detonation causing the plug gap to close but I can’t find anything anywhere about plug gaps increasing. Does anybody know if this is a thing? Thanks for any help in advance, I’ve learned a ton on here while I’ve been building both of my ‘shees. Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
the boris Posted February 2, 2020 Report Share Posted February 2, 2020 Following Sent from my VOG-L29 using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 2, 2020 Report Share Posted February 2, 2020 That doesn't make any sense.. Have you backed it up with a second set of plugs? Quote Link to comment Share on other sites More sharing options...
kawa110 Posted February 2, 2020 Report Share Posted February 2, 2020 To lean will gap plugs faster then normal. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deets Posted February 2, 2020 Report Share Posted February 2, 2020 I’ve never seen anything like that Quote Link to comment Share on other sites More sharing options...
