jnormie917 Posted January 12, 2020 Report Share Posted January 12, 2020 So yesterday I bought a 2003 Banshee on OfferUp for a steal. The guy bought it from his brother in law who built it and from the looks of it put several thousand into it. After using it only a handful of times, he got too busy and it sat in his garage for 2-3 years. It's got a Coolhead, full Toomey T5 exhaust, extended swingarm, custom billet clutch and stator covers, hot rods, ported cylinders, extended radiator, adjustable billet stator plate, and a few other things I think. It's been bored somewhere in the neighborhood of 2.5mm over stock as near as I can tell, I haven't been able to measure it with calipers or a bore gauge yet. So the sad part is that from the looks of it last time it was taken apart/rebuilt, it got slapped back together in a hurry. There's gasket maker on pretty much every seam where there should have been a proper gasket (heads, clutch cover, between the cases, and all over the boots on the reed cages). I have the engine completely disassembled and cases split as of right now. When taking out the clutch, I noticed there is a pretty good amount of play between the clutch basket and the gear on it, which from what I've read indicates bad cushions. I'm putting together a list of everything I need to buy to get it running, but I want to save as much as I can where possible. Right now my question is how bad is it to run on bad clutch cushions? Will it lead to further damage down the road or affect performance? Quote Link to comment Share on other sites More sharing options...
the boris Posted January 12, 2020 Report Share Posted January 12, 2020 Don't do it, try to save money some other way, if that clutch basket keeps smashing every time you accelerate, eventually it will crack and break, and in that case, you will have very expensive repair on your hands. Sent from my VOG-L29 using Tapatalk Quote Link to comment Share on other sites More sharing options...
the boris Posted January 12, 2020 Report Share Posted January 12, 2020 The best way to save money is to do whole repair and rebuild yourself (which you are already doing, must say well done) but don't cut corners on parts because that is very risky thing to do. Sent from my VOG-L29 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tedder Posted January 12, 2020 Report Share Posted January 12, 2020 If it's got an aftermarket basket I'll send you some cushions for it N/C but if it's OEM with the two oddball size pucks I can't help you. Quote Link to comment Share on other sites More sharing options...
jnormie917 Posted January 12, 2020 Author Report Share Posted January 12, 2020 Yeah, mine's got the stock basket with the rivets on the back... Looking a bit closer it looks like it had been run on the bad cushions for a while since there's some pretty severe deformation of the basket/hub where the plates were slamming into them. Anyone know of a good kit that has a basket hub and plates, or will I need to get them separately? I was thinking of going with Tusk competition plates and hd springs from Rocky Mountain ATV, but if I could get everything in a set I'd probably do that. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted January 13, 2020 Report Share Posted January 13, 2020 Matoon machine on EBay. Only one to buy! Quote Link to comment Share on other sites More sharing options...
jnormie917 Posted January 14, 2020 Author Report Share Posted January 14, 2020 Thanks, definitely will look into that one. So if I get a billet basket, do I need to upgrade the pressure plate as well or do the stock ones work ok? Quote Link to comment Share on other sites More sharing options...
SKEETER Posted January 14, 2020 Report Share Posted January 14, 2020 You'll use your stock pressure plate. X2 on mattoon basket. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted January 14, 2020 Report Share Posted January 14, 2020 Any anodized baskett will be good.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 14, 2020 Report Share Posted January 14, 2020 I have a chariot billet basket that needs some love ( hole to be tapped) and new cushions if you wanna save money, ill sell it to you cheap. 1 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted January 14, 2020 Report Share Posted January 14, 2020 If he not interested I am^^^^^Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
the boris Posted January 14, 2020 Report Share Posted January 14, 2020 I will stand in the line too. Sent from my VOG-L29 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 14, 2020 Report Share Posted January 14, 2020 57 minutes ago, kawa110 said: If he not interested I am^^^^^ Sent from my iPhone using Tapatalk pmd Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 14, 2020 Report Share Posted January 14, 2020 24 minutes ago, the boris said: I will stand in the line too. Sent from my VOG-L29 using Tapatalk noted 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 17, 2020 Report Share Posted January 17, 2020 Get a new basket, inner hub, and make sure your pressure plate is good to go. Quote Link to comment Share on other sites More sharing options...
