375hp banshees Posted January 18, 2020 Report Share Posted January 18, 2020 Have them order the correct pistons and replace the head. ^ this at no charge & make sure you get correct base gasket as well!Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deets Posted January 18, 2020 Report Share Posted January 18, 2020 5 hours ago, Keno said: Have them order the correct pistons and replace the head. Pretty much what needs to be done Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted January 18, 2020 Report Share Posted January 18, 2020 12 hours ago, the boris said: Milling head won't affect port timing, thicker or thinner base gasket will affect port timing and compression. Sent from my VOG-L29 using Tapatalk Depends though, going from a .020 to a .015 will be a marginal change enough to tighten the squish and compression a few but won’t effect port timings negatively Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 20, 2020 Report Share Posted January 20, 2020 On 1/17/2020 at 10:42 PM, the boris said: Isn't blaster 250cc single cylinder? Sent from my VOG-L29 using Tapatalk 200cc 1 Quote Link to comment Share on other sites More sharing options...
