Just wanna hear others,what rpm range does it kick in on your bikes and what modes do you have?
FMF pipes
Vf3 reed
K&N filter
4 degrees timing advance
Stock cylinders
Stock bore
Mine kicks in between 5000-6000,not sure where to go from there to lower it a bit.
Sent from my ONEPLUS A3000 using Tapatalk
  • Like 1
  • 3 weeks later...
On any two stroke, you’ll be hard pressed to get it to come on hard before 5k. Most of the mods you have help, but maybe a pipe change to SLP’s could help, but not much. The other option to really get it snappy would be to switch to race fuel and give it some more compression and timing.
  • Like 1
