375hp banshees Posted December 22, 2019 Report Share Posted December 22, 2019 What gender neutral shifting juice does ary body recommend? Quote Link to comment Share on other sites More sharing options...
SKEETER Posted December 22, 2019 Report Share Posted December 22, 2019 ATF type f, change every 300hrs of use. Quote Link to comment Share on other sites More sharing options...
registered user Posted December 23, 2019 Report Share Posted December 23, 2019 the gears and bearings wont care what u put in there. clutch action might be a bit better with some oils though Quote Link to comment Share on other sites More sharing options...
ric-ross1 Posted December 23, 2019 Report Share Posted December 23, 2019 Olive oil extra virgin is my choice, nice and smooth!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 23, 2019 Report Share Posted December 23, 2019 I use Belray gear saver for wet cutch.Envoyé de mon SM-G965W en utilisant Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted December 23, 2019 Report Share Posted December 23, 2019 Diesel fuel Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 23, 2019 Report Share Posted December 23, 2019 What is the application? Drag, trail, etc. On a drag bike, its virtually inevitable that you will be wrenching on it, so ATF has always been my go to because its cheap and works fine. If its a daily rider, duner, trail type deal where you just want to add gas and ride, then I would recommend a Redline, or something along those lines. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted December 23, 2019 Report Share Posted December 23, 2019 Royal purple Quote Link to comment Share on other sites More sharing options...
Keno Posted December 24, 2019 Report Share Posted December 24, 2019 What gender neutral shifting juice does ary body recommend?The gender fluid fluid of choice is tranny oil.I use Rotella T6 5w-40. Cheap enough and works well for a play bike. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted December 24, 2019 Report Share Posted December 24, 2019 per tyson mobile 1 0W20 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 24, 2019 Author Report Share Posted December 24, 2019 What if tyson didn't dewit...Thanks for duh info, ima stick wit astroglideSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
SKEETER Posted December 24, 2019 Report Share Posted December 24, 2019 Your BH will appreciate anything I'm sure. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 28, 2019 Report Share Posted December 28, 2019 Bel Ray or Amsoil Super Shift ATF. Really you can run whatever oil is wet clutch compatible. The cheapo ATF is fine, just needs to be changed more frequently. 1 Quote Link to comment Share on other sites More sharing options...
