the boris Posted January 4, 2020 Author Report Share Posted January 4, 2020 I do not, I’ve only ported small single cylinder 2 strokes, chainsaws. But, installing a timing wheel should be the same. mount the wheel on the crank, set the wheel at tdc with corresponding piston at tdc. Then read port openings. Exhaust roof, transfer roofs, intake floor. To do that should I have to have a head off of the engine? Sent from my VOG-L29 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deets Posted January 4, 2020 Report Share Posted January 4, 2020 7 hours ago, the boris said: To do that should I have to have a head off of the engine? Sent from my VOG-L29 using Tapatalk well like I said, I haven’t done it on a banshee yet. On a saw I use a plastic piston stop, roll the engine around till it stops and check number. Roll it backwards till it hits the stop and check number. You need to adjust your timing wheel so it stops the same amount of degrees before tdc each way, then it’s good. On a banshee it may be easier to use a tdc indicator. Either way the head would need to be on to find true tdc. 1 Quote Link to comment Share on other sites More sharing options...
