Dad's Banshee Problems Part II
nj2016
So my dad is having problems with his bike again after having some work done, this is exactly what he sent me
"received new top end with minor head work and replaced factory TORS carb tops with aftermarket
now:
no power band  the right side pipe doesn't get hot  and when you but hand behind tail pipe
left side is hot and dry  right side gets wet from gas and is not hot
changed plugs several times
changed wires from one plug to other to see if it was wire etc made no difference
carbs have to be working because  fuel is coming out tail pipe
took off reed cage both sides see no obstructions and checked that pistons were going up and down
through reed cage opening"
I had him check compression, if I remember what he said correctly it was 90 on the side that was running right and 85 on the other. Any ideas would be greatly appreciated. Thanks.
now:
Are you in nj?
Sent from my SM-G970U using Tapatalk
