Stelton87 Posted December 6, 2019 Report Share Posted December 6, 2019 So my banshee seems to run fine on both cylinders at idle but when I get in to the higher rpms the right cylinder seems to dead out and stop firing compression seems OK did the thumb trick and both seem the same. Both plugs have spark I cleaned carbs she's geting plenty of fule also checked reeds. Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
Keno Posted December 6, 2019 Report Share Posted December 6, 2019 Verify that the carb slides are opening the same. Adjust with the adjusters on top of the caps. Quote Link to comment Share on other sites More sharing options...
rkooienga Posted December 6, 2019 Report Share Posted December 6, 2019 I agree with Keno, sounds like a carb issue. Also do an actuall compression test with a quality gauge. Also it might be an air leak, but best guess is carb. I had the same issue but mine was the left cylinder and the carbs werent sank, now it runs great though. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 6, 2019 Report Share Posted December 6, 2019 Carb bowls on correct sideChoke tube onCarbs cleanJets correct size and clearCarbs synchronization is correct If one hole goes dead, I’d place bets on carbs. Do a real compression check so (1) you know it’s good, and (2) so you have a baseline that you can refer to as things wear out. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 6, 2019 Report Share Posted December 6, 2019 Check all of the above. ^ Ricky, ricks, or RM stator? Check the pick up gap. That’s the sensor to the flywheel tabs. Check the spark plug boots and make sure the end of the wire is also good. Do the spark plugs have solid tops or do they have that bull shit twist on top? Quote Link to comment Share on other sites More sharing options...
