Slipping at high RPM
Ladle58
I'm stumped a little bit on this.  I'm sure it's something stupid but maybe someone has had the same issue and can shed some light.
At higher RPM, I occasionally get what I can only describe as an over rev without the power.  This issue started after I did a rebuild on the top end.  After some thought, it made sense that it was time to replace the clutch plates thinking the over rev was caused from slippage in the plates.  I replaced the clutch plates and the clutch basket and adjusted the clutch arm/cable. It is still doing the same over rev.  It tends to go away as it warms up.
Looking for some input. One last thought is maybe the parking brake sensor is somehow messing with the revving issue.  Any help on this would be greatly appreciated.
Thanks!
