Tobynblevins Posted November 23, 2019 Report Share Posted November 23, 2019 (edited) I have a banshee its pretty much stock and I'm buying new keihin PWK 28mm or 30mm carbs my banshee is bored the next size over I think the cylinder is ported for trail not sure tho I have dmc pipes and everything else is stock. Guy who sent me the cylinders did not tell me he ain't known what port job was on them before I ordered so I'm not sure what port it on them.. and this form wont let me upload pictures no matter how many times I cut the picture Edited November 23, 2019 by Tobynblevins Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 23, 2019 Report Share Posted November 23, 2019 28’s would only be a marginal gain in power, but you will gain a bit of torque and have a much more responsive ride. You could step in to some 33’s, but they would be overkill for what you’ve got and you’d lose bottom end. What 30’s were you looking at? If they’re OKO’s jdont bother. Quote Link to comment Share on other sites More sharing options...
Tobynblevins Posted November 23, 2019 Author Report Share Posted November 23, 2019 2 hours ago, trickedcarbine said: 28’s would only be a marginal gain in power, but you will gain a bit of torque and have a much more responsive ride. You could step in to some 33’s, but they would be overkill for what you’ve got and you’d lose bottom end. What 30’s were you looking at? If they’re OKO’s jdont bother. I already ordered keihin 28s I wont go past 30s.. I think no matter what mods 30s is enough. Quote Link to comment Share on other sites More sharing options...
Keno Posted November 24, 2019 Report Share Posted November 24, 2019 Well considering Keihin doesn't make 30mm carbs. Stick with the 28s. Quote Link to comment Share on other sites More sharing options...
gusto Posted November 24, 2019 Report Share Posted November 24, 2019 Stock carbs Quote Link to comment Share on other sites More sharing options...
Tobynblevins Posted November 24, 2019 Author Report Share Posted November 24, 2019 (edited) 7 hours ago, Keno said: Well considering Keihin doesn't make 30mm carbs. Stick with the 28s. I can buy a keihin 28 tap bored to 30 that's never been used. Keihin makes that carb....you are correct they don't make 30s..but I can buy a keihin 30mm Edited November 24, 2019 by Tobynblevins Quote Link to comment Share on other sites More sharing options...
gusto Posted November 24, 2019 Report Share Posted November 24, 2019 Put your money elsewhere and run the stock carbs. Will be no difference on your engine. Unless you actually need carbs, I’d keep the stock ones and put money into go fast parts 1 Quote Link to comment Share on other sites More sharing options...
Tobynblevins Posted November 25, 2019 Author Report Share Posted November 25, 2019 On 11/24/2019 at 11:59 AM, gusto said: Put your money elsewhere and run the stock carbs. Will be no difference on your engine. Unless you actually need carbs, I’d keep the stock ones and put money into go fast parts Definitely need carbs my stock ones are knock off so technically they not stock... I cant jet them they dont make jets for them that I need or can find.. they koso carbs 1 Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 28, 2019 Report Share Posted December 28, 2019 On 11/24/2019 at 11:59 AM, gusto said: Put your money elsewhere and run the stock carbs. Will be no difference on your engine. Unless you actually need carbs, I’d keep the stock ones and put money into go fast parts Not true. I f'd around with oem Mikuni 26s for years and could never get the jetting right, had problems with engine run-away whenever I splashed through a puddle, poor low end power and throttle response and a distinct lag when hitting the throttle hard. Put Keihin Pwk-28 carbs in and it jetted easily, ran like like a new machine with consistent throttle response across the entire throttle range and no more lag waiting for the power band to hit. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 28, 2019 Report Share Posted December 28, 2019 1 hour ago, muggzy said: Not true. I f'd around with oem Mikuni 26s for years and could never get the jetting right, had problems with engine run-away whenever I splashed through a puddle, poor low end power and throttle response and a distinct lag when hitting the throttle hard. Put Keihin Pwk-28 carbs in and it jetted easily, ran like like a new machine with consistent throttle response across the entire throttle range and no more lag waiting for the power band to hit. If water and jetting was issue on your stockers, that’s typically a sign that the slide guide/plug is leaking as well as the seal on the caps. Quote Link to comment Share on other sites More sharing options...
Deets Posted January 4, 2020 Report Share Posted January 4, 2020 Are the carbs marked on the outside what they are? Or do I have to pull the carbs and measure? Quote Link to comment Share on other sites More sharing options...
SandSlingerOR Posted January 7, 2020 Report Share Posted January 7, 2020 28s. I liked em on my bolt on motor set up vs the stockers. Quote Link to comment Share on other sites More sharing options...
Deets Posted January 7, 2020 Report Share Posted January 7, 2020 I used to always be a fan of flat slides, but that was on a snowmobile. What do you guys prefer? Round or flat slides? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 17, 2020 Report Share Posted January 17, 2020 Flat Quote Link to comment Share on other sites More sharing options...
muggzy Posted January 19, 2020 Report Share Posted January 19, 2020 If water and jetting was issue on your stockers, that’s typically a sign that the slide guide/plug is leaking as well as the seal on the caps. That's an interesting idea. If I still had the carbs, I'd pursue it. In spite of the rediculous number of posts I put on Bhq and other forums, this is the first I heard of that theory. It's certainly worth checking out. I can say for certain, that it wasn't the seal on the caps,but I never checked the slide Glide or plug on the carbs. Despite the possibility that you're right, there aren't any plugs on the Keihins to leak. So if the problem was leaky plugs, problem solved anyway with a better airflow on the intake in the exchange. Sent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
