ClaudeMachining Posted November 22, 2019 Report Share Posted November 22, 2019 I just putted out the clutch cover. The water impeller is very hard to turn by hand. Is it normal??? I know there is a mechanical seal and a spring but dam that thing is hard to turn by hand!!! Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted November 22, 2019 Report Share Posted November 22, 2019 no idea. glad you bought it, im curious to know how you like the handling/ride? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 22, 2019 Author Report Share Posted November 22, 2019 no idea. glad you bought it, im curious to know how you like the handling/ride?It's winter here, so i'll ride it in about 6 months ;-)Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted November 22, 2019 Report Share Posted November 22, 2019 It’s winter here and that’s when everyone rides, especially on the ice. Put down the purse, put on your toque and ride 1 Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted November 22, 2019 Report Share Posted November 22, 2019 It's winter here, so i'll ride it in about 6 months ;-)Envoyé de mon SM-G965W en utilisant TapatalkYour going to like the tight woods riding. Sent from my LG-H873 using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 22, 2019 Report Share Posted November 22, 2019 I rode a 310 esr built bike. I was very unimpressed. Handles pretty good. But very lacking in the power delivery. Sent from my SM-G970U using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 22, 2019 Author Report Share Posted November 22, 2019 I rode a 310 esr built bike. I was very unimpressed. Handles pretty good. But very lacking in the power delivery. Sent from my SM-G970U using TapatalkSure, you are used to banshee kind of power ;-)Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 22, 2019 Report Share Posted November 22, 2019 im assuming its like a banshee with a gear on the other end which runs off a water pump gear on the crank, id imagine it would be hard to turn, it would be like trying to rotate the crank by using the impellar am i right? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 22, 2019 Author Report Share Posted November 22, 2019 im assuming its like a banshee with a gear on the other end which runs off a water pump gear on the crank, id imagine it would be hard to turn, it would be like trying to rotate the crank by using the impellar am i right?Not the same system at all. It's hard ro turn even when it's removed from the engineThey use a mechanical seal/spring assembly, so there is a lot of friction, especialy when it's new.But since im new to that kind of system, i dont know when hard become "too hard".Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 22, 2019 Report Share Posted November 22, 2019 oh word. no idea then. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 22, 2019 Author Report Share Posted November 22, 2019 oh word. no idea then. Just for the sake of the conversation, i'll take a pic for ya tonight.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted November 22, 2019 Report Share Posted November 22, 2019 Y did u pull the cover? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 22, 2019 Author Report Share Posted November 22, 2019 Here is the cover. The engine was running good so i guess it's normal to be as tight.Almost finished my porting on the engine. I did intake, transfer, boost port and exhaust.I didnt touch the ports timing.Envoyé de mon SM-G965W en utilisant Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
registered user Posted November 23, 2019 Report Share Posted November 23, 2019 there will be some resistance turning the shaft because the seals and maybe a tight fit of the bearing. from old memory of different bikes i took apart it seems like they could still turn by hand. been a while since i taken that stuff apart though Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 23, 2019 Author Report Share Posted November 23, 2019 there will be some resistance turning the shaft because the seals and maybe a tight fit of the bearing. from old memory of different bikes i took apart it seems like they could still turn by hand. been a while since i taken that stuff apart thoughThere is no way i can turn it by the shaft. I have to grab the impeller to be able to turn itEnvoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
