Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 Not there is that ok Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2019 Report Share Posted November 23, 2019 Just now, Johnson87 said: Not there is that ok Fine, totally not needed Quote Link to comment Share on other sites More sharing options...
Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 My key switch doesn't work either Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2019 Report Share Posted November 23, 2019 3 minutes ago, Johnson87 said: My key switch doesn't work either Need to have continuity from Black/Red to Red for it to run. Quote Link to comment Share on other sites More sharing options...
Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 Just jump a wire across them will work right? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2019 Report Share Posted November 23, 2019 2 minutes ago, Johnson87 said: Just jump a wire across them will work right? Yep. And if you need to test the thumb switch, just unplug it. Quote Link to comment Share on other sites More sharing options...
the boris Posted November 23, 2019 Report Share Posted November 23, 2019 I had similar problem but in my case was faulty spark plug cups ,they have resistors inside and they went kaput.Just something to keep in mind in case everything else passes the test and turns out to be good.Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
the boris Posted November 23, 2019 Report Share Posted November 23, 2019 This is tors box,mine is just unpluggedSent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
the boris Posted November 23, 2019 Report Share Posted November 23, 2019 And this is key override, I just soldered vires together and put the cap Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 Ok so it will still spark with the kill switch unplugged to Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2019 Report Share Posted November 23, 2019 20 minutes ago, Johnson87 said: Ok so it will still spark with the kill switch unplugged to Is that a question or a statement? Quote Link to comment Share on other sites More sharing options...
Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 Sorry that's a question I'm bad when it comes to electrical Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2019 Report Share Posted November 23, 2019 The thumb switch grounds out the system to kill it, so it will run unplugged. 1 Quote Link to comment Share on other sites More sharing options...
Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 Man am I glad I joined this site everyone has been more then helpful if I didn't join this I would of burned this thing or just kept buying useless parts Quote Link to comment Share on other sites More sharing options...
Johnson87 Posted November 23, 2019 Author Report Share Posted November 23, 2019 So no power coming out of stator just order oem new one Quote Link to comment Share on other sites More sharing options...
