Banshee won't start
Johnson87
2 minutes ago, Johnson87 said:
Stupid question how do you do a leak down test on this
I just asked the same question the other day. You need the correct equipment. cover the exhaust and one of the carb boots. The gauge and pump go into the other carb boot. Make sure both plugs are tight and pump to six psi. I believe(cant remember exactly.) it should hold six psi for a full minute to be perfect.
Just now, Pinkylee said:
He sells leak down kits... Or you can just build your own.
Yeah they told me to look up his videos too. When your doing the test. If the psi doesnt hold pull the vent hoses to the bottom end and put some soapy water over them. There should be no bubbles coming out of them.
Rooienga has got it right except it should be 6 psi for 6 mins. While not loosing more than 1 psi.
Thats what I thought but that sounded to long. But I thought it was exceptable/spec was to lose no more than one psi a minute. Not one psi total.
