rkooienga Posted November 21, 2019 Report Share Posted November 21, 2019 Alright I have two questions. The first is What is an exceptable compression psi. For a freshly rebuild banshee with 65mm bore. (not sure if bore matters.)/ what is the method to complete said comp test? Secondly What is the correct/most commonly used process of breaking in a banshee? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 21, 2019 Report Share Posted November 21, 2019 Test...both plugs out, hold throttle wide open, kick until needle stops climbing on the gauge. Same for other side. Break-in...warm up good, checking for leaks. Shut off, cool down, re-torque head and cylinders. Warm up again then ride it for all it's worth. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 22, 2019 Report Share Posted November 22, 2019 Acceptable PSI in a stock head rebuild with a couple bores like yours, 130ish. Do you have a stock head or cool head on it? Dennis is spot on with break in. Just be get it warm and check it all over a couple times. Take it for an easy cruise and listen to it. If it’s all good, beat the snot out of it. Quote Link to comment Share on other sites More sharing options...
the boris Posted November 22, 2019 Report Share Posted November 22, 2019 I usually give it few heat cycles of mild ride before I step on it,with checks in between and,as someone already said,listen to it,if some new sound appears, shut it off and investigate.Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
rkooienga Posted November 22, 2019 Author Report Share Posted November 22, 2019 13 hours ago, the boris said: I usually give it few heat cycles of mild ride before I step on it,with checks in between and,as someone already said,listen to it,if some new sound appears, shut it off and investigate. Sent from my ONEPLUS A3000 using Tapatalk Ok I did two heat cycle of about ten minutes. I will be gentle today for a few minutes while I really listen too it. Then ill step on it for a while. Quote Link to comment Share on other sites More sharing options...
