mrparty21 Posted November 1, 2019 Report Share Posted November 1, 2019 I have a 421 Banshee with 38mm pwk carbs. I’m running a moose throttle right now and the thumb throttle stars too far in front of the bars which causes my thumb and hands to cramp up immediately. i thought about running the moose dual gasser so I can have a twist and thumb throttle but I heard those aren’t good and the thumb will still be uncomfortable i found that chariot made a nice throttle that will open 38mm carbs and it has an adjustable thumb lever but he apparently stopped making them a few years ago My ideal option would be to run a Honda throttle but from what I’ve read those will only open up a 35mm carb once the inside of the throttle has been ground out to the max so I think my only option is to switch to 28mm pwk carbs and run a Honda throttle. Unless anyone else has any suggestions? Let me know what you guys think, thanks. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 1, 2019 Report Share Posted November 1, 2019 Look into Urmosi throttles. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 1, 2019 Report Share Posted November 1, 2019 I run a Honda with my 35s. I believe the 38s are possible with the correct adjusters on top. I think the 41s are impossible. Urmosi is nice, I've ridden bike with one. It was okay. Not worth what he ask I think. But if you do get 1, ask him if itll work. Also get the pro one or what ever. It is updated to the old one. Sent from my SM-G970U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Keno Posted November 1, 2019 Report Share Posted November 1, 2019 You really can't adjust the thumb position? Geeze. Looks like Chariot still has some red and chrome throttles in his eBay store. Edit: Holey poop, the Urmosi pro is over $300. I would try the trx90 lever in a Honda 400ex/450r housing thing first. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted November 1, 2019 Report Share Posted November 1, 2019 ^^^^^^ Best way to go. Honda 400ex throttle housing, trx90 thumb lever, E-Z pull springs for the carb slides with 2 coils cut off the bottom, new throttle cable lubricated generously. I have 39mm PWK's, and aluminum had to be welded to a few areas of the housing. After that was done, I took a dremel to the inside and removed material away so I could get full range of motion on my lever. Best setup IMO. Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted November 1, 2019 Report Share Posted November 1, 2019 Terry Cable dual gasser. Call and explain what you want and they'll make it soft for your soft hands. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 3, 2019 Report Share Posted November 3, 2019 OEM FTW! Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted November 4, 2019 Report Share Posted November 4, 2019 Urmosi FTMFW! 2 Quote Link to comment Share on other sites More sharing options...
SKEETER Posted November 4, 2019 Report Share Posted November 4, 2019 Leave you're purse at home FTW Quote Link to comment Share on other sites More sharing options...
DuneRat Posted November 4, 2019 Report Share Posted November 4, 2019 Twister would be pretty cool. I run a push throttle. Im thinking about a twist throttle Quote Link to comment Share on other sites More sharing options...
kawa110 Posted November 4, 2019 Report Share Posted November 4, 2019 Twist throttle on atv=death trapHonda with a 90 lever, ez springs cut down. Or ride more and your hand/thumb will build the strength over time. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dano3 Posted November 5, 2019 Report Share Posted November 5, 2019 400EX thumb throttle, cutting 4 coils off the OEM PWK springs, and lubing the cable with the motion pro cable lube/tool made a huge difference on my 35MM carbs. I need to try the trx90 lever next. Quote Link to comment Share on other sites More sharing options...
DuneRat Posted November 6, 2019 Report Share Posted November 6, 2019 if you got prime you could have a chinese "billet" thumb throttle in a day. Not too convinced on that Quote Link to comment Share on other sites More sharing options...
gusto Posted November 6, 2019 Report Share Posted November 6, 2019 https://www.amazon.ca/Everlast-Extra-Strength-Hand-Grips/dp/B007K3D2AK/ref=asc_df_B007K3D2AK/?tag=googlemobshop-20&linkCode=df0&hvadid=292942511498&hvpos=1o1&hvnetw=g&hvrand=10523017929525420437&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1001801&hvtargid=pla-458985546954&psc=1 Quote Link to comment Share on other sites More sharing options...
specialblend07 Posted November 6, 2019 Report Share Posted November 6, 2019 On 11/4/2019 at 4:26 PM, kawa110 said: Twist throttle on atv=death trap Sent from my iPhone using Tapatalk LOL this couldn't be anymore from the truth. Quote Link to comment Share on other sites More sharing options...
