should i mvoe back to my stock carbs or should i change my pipe i dont know what is wrong with my shee the bottom is kind of good by the problem is with the midrange the top is good.
second my pipe is a drag pipe what i need is another set of pipes somthing to play around with could u guys please help me out
so you want a low to mid pipe, or a good al around pipe, if you want low to mid get a dynoport or motofast 2-1 pipe, if you want all around ive heard good about the trinity's and the t3's
Have you tried adjusting the needle clip position? Sounds like it may just be a jetting issue. Once you get the jetting dialed in the drag pipes may be fine for play riding (not sure what you got in Kuwait but I envision dunes, top end pipes would be good for that). Good luck.
