Stock rear spring measurements
Glamisrider
Anybody know or can link a thread that has the stock rear spring measurements?
Looking for length, Inside Diameter are the main ones.  If someone knows the compressed coil bind height, number of coils, and coil diameter, that'd be great too.
Going to respring the stock rear, I'm 225lbs with stock swinger, ride glamis only.  Looking at 450lbs/inch to 475lbs/inch any experience or recommendations?
Thanks
You’ll be better off just having it built by a third party. It’s a great shock once you go through it.
The valving needs as much attention as the spring.
What is your ride height at that you want that much larger of a spring? The rule of thumb is that if you have to compress the spring more than an inch to get ride height, you need a stiffer spring.
