Atvrider6566 Posted October 28, 2019 Report Share Posted October 28, 2019 I just rebuilt the bottom end in my 98 banshee and I got a whole new oem clutch and when I tried to put it together all the fibers and clutches wouldn’t fit into the clutch basket, the last fiber sticks out by about a quarter of an inch, I am following the clymer’s manual exactly and am out of ideas. Any ideas on what I should do? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Keno Posted October 28, 2019 Report Share Posted October 28, 2019 Post pictures Quote Link to comment Share on other sites More sharing options...
Atvrider6566 Posted October 28, 2019 Author Report Share Posted October 28, 2019 Post picturesSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Keno Posted October 28, 2019 Report Share Posted October 28, 2019 For some reason the bottom friction isn't sitting down far enough. If you have the clutch cushion rings, they can be removed. Quote Link to comment Share on other sites More sharing options...
Atvrider6566 Posted October 28, 2019 Author Report Share Posted October 28, 2019 For some reason the bottom friction isn't sitting down far enough. If you have the clutch cushion rings, they can be removed.Okay because I was told that the stock clutch needs the cushion rings in it and that you could only remove them with an aftermarket clutchSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 28, 2019 Report Share Posted October 28, 2019 none of them "need" the cushion rings Quote Link to comment Share on other sites More sharing options...
rkooienga Posted November 14, 2019 Report Share Posted November 14, 2019 If you are using the cushions every time you put a friction plate in you have to press the cushion in very firm to fit all the plates. I had the same problem cause the cushions weren’t flat with the face of each friction plate. Quote Link to comment Share on other sites More sharing options...
Khannon215 Posted December 28, 2023 Report Share Posted December 28, 2023 bump Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 29, 2023 Report Share Posted December 29, 2023 On 12/27/2023 at 10:28 PM, Khannon215 said: bump Why? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 30, 2023 Report Share Posted December 30, 2023 That bottom plate isn't down all the way. Is this issue sorted? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 30, 2023 Report Share Posted December 30, 2023 NO thank you oh wize1 i been waiting...over 4years Tanks! Sent from my iPhone using Tapadumbass Quote Link to comment Share on other sites More sharing options...
Khannon215 Posted December 31, 2023 Report Share Posted December 31, 2023 well I'm no mechanic and someone correct me if I'm wrong, but here is my take on the clutch basket, inner hub and pressure plate gap mystery. In my hours of taking my clutch side casing on and off, I found that the first have to understand what you're looking for. I only say this because I repeated the process of making sure the arrows were lined up, start with a fiber and end with a fiber, checking for washers, and my least favorite draining fluids as the defeat grew day by day and in the end the resolution was quite simple, had I just slowed down. Second, a picture really is worth a thousand words because your problem might not be my problem. However in my instance I had a 3CM gap in-between the pressure plate and the actually hub the plate locks into. Despite the gap with all 6 of the screws and springs that mount the pressure plate to the hub in place the clutch lever had no play and was taut, as if shee were ready to rip! Now, initially I thought the gap was due to the fact that I had oversized heavy duty clutches and they didn't quite fit in the basket. The 7 clutch fibers and 6 steels just seemed too big! So in turn got a new set of moose racing clutches and install those instead. Theses seemed to seat down in the basket perfectly. BUT HERES the kicker, I install the pressure plate and THE FRICKING GAP IS STILL THERE! I fill the bike with fluids and still test it to see if I'm seeing things at this point, because there's no way I spent an additional $200 and still NO dice. When I slap her in gear Shee just idles not a lick of movement STUMPED I then shut the bike off and put it in second and Im able to start the bike with no clutch. I quickly realize that it's as if the clutches are always engaged . SO the Clutches fit the basket flush, the 3 dots are lined up with the respective arrows on the hub, started with fiber and ended with one, and the clutch arm lines up with the dot on the casing. Here was MY Problem the washer behind the center 12 screw was obstructing the pressure plate from fully seating, which led to the clutch malfunction. Here's what I came up with. The first set of clutches I had were good ( I did in fact waste 200 bucks). Atleast I'll have them if anything. Solution was simple I loosened the center 12 screw maybe two turns and noted a suction cup like noise and the disappearance of the nuisance of a gap. The pressure plate , granted its in working order and you're putting 7 clutches in a 7 clutch basket, should hold the clutches snug to the basket and you be able to confirm this by two test. The suction ( sound like a suction cup when you pull your lever ) test before you put your side casing back on and secondly by putting it in gear. Hopefully this helps. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 31, 2023 Report Share Posted December 31, 2023 👏👏👏well said I think Did anybody read ...ALL that? Quote Link to comment Share on other sites More sharing options...
Khannon215 Posted January 1 Report Share Posted January 1 Hey 375 I think I know why it's taken you 4 years to figured this one out! You could've found a nicer way to say you're illiterate and use speech to text lol! Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted January 1 Report Share Posted January 1 Yeah, some of us are slow. Why, I don't want to hear it read to me, any more than I wanted to read it. Quote Link to comment Share on other sites More sharing options...
