BansheeUSA Posted October 26, 2019 Report Share Posted October 26, 2019 So I had an accident where I thought my axle was damaged well from what I was told. I took the axle out and replaced the axle. I still have tire wobble at all speeds. Could it be the hole shot tires or is it something else. Could it possibly be the sleeve in between bearings? I also changed bearings running out of ideas. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted October 26, 2019 Report Share Posted October 26, 2019 Jack it up & run it, & see if that shows anything outa round? Quote Link to comment Share on other sites More sharing options...
0sikshee Posted October 26, 2019 Report Share Posted October 26, 2019 Probably a wheel or hub... but do what 375hp suggestedSent from my SM-G955U using Tapatalk Quote Link to comment Share on other sites More sharing options...
BansheeUSA Posted October 27, 2019 Author Report Share Posted October 27, 2019 2 hours ago, 375hp banshees said: Jack it up & run it, & see if that shows anything outa round? Hey do you have an Facebook I could send you the video through messenger. Quote Link to comment Share on other sites More sharing options...
Pinkylee Posted October 27, 2019 Report Share Posted October 27, 2019 12 hours ago, 0sikshee said: Probably a wheel or hub... but do what 375hp suggested Sent from my SM-G955U using Tapatalk X2 Quote Link to comment Share on other sites More sharing options...
Pinkylee Posted October 27, 2019 Report Share Posted October 27, 2019 Switch wheels..see if problem follows... If not ? Switch hubs and see if problem follows. 12 hours ago, 0sikshee said: Probably a wheel or hub... but do what 375hp suggested Sent from my SM-G955U using Tapatalk X2 Quote Link to comment Share on other sites More sharing options...
BansheeUSA Posted October 27, 2019 Author Report Share Posted October 27, 2019 25 minutes ago, Pinkylee said: Switch wheels..see if problem follows... If not ? Switch hubs and see if problem follows. X2 Thanks I will be switching wheels and posting results. Quote Link to comment Share on other sites More sharing options...
