Domenick Posted October 17, 2019 Report Share Posted October 17, 2019 I have a 93 Yamaha banshee that I have rebuilt. I have a brand new ignition brand new ignition coil full wiring harness CDI box new stater and fly wheel new spark plugs. I still cannot get a spark. I’ve tried disconnecting the Killswitch completely unplugged it still cannot get a spark the ground is clean and grounded properly still cannot get a spark. don’t know if it has anything to do with the tors system. Can anyone please help Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 17, 2019 Report Share Posted October 17, 2019 Key switch? And when you unplugged the on off switch, did you jump it? Or just unplug it?Sent from my SM-G970U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 21, 2019 Author Report Share Posted October 21, 2019 I jumped it or use the wire with the two wins I went from the black to the black with the white line still no spark. Everything is brand new the ground is grounded correctly I took apart the Killswitch cleaned all the connectors I still have no spark?? Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 21, 2019 Author Report Share Posted October 21, 2019 Also replaced the Stator and flywheel When testing the Ormes the pick up coil is at 30 but it is gapped correctly Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 21, 2019 Report Share Posted October 21, 2019 Black to Black/White will kill it. That's the thumb switch. The Key switch when disconnected need jumped. Unplug the # wire TORS box under the left side of the fuel tank to disconnect that system. Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 21, 2019 Author Report Share Posted October 21, 2019 So unplug the TORS box and see if I have spark how do I jump the key switch the ignition key switch is brand new Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 21, 2019 Report Share Posted October 21, 2019 20 minutes ago, Domenick said: So unplug the TORS box and see if I have spark Yes how do I jump the key switch Jump Red and Black/red the ignition key switch is brand new Some are actually backwards, off is on and on is off. From a Blaster I think, but places sell them as Banshee Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 21, 2019 Author Report Share Posted October 21, 2019 Thanks for the info I will try as soon as I get home tonight and I will let you know how I make out Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 21, 2019 Author Report Share Posted October 21, 2019 I know I haven’t jumped the key switch but I have turned it to off no spark in on no spark so I have no spark whether it’s on or off Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 21, 2019 Report Share Posted October 21, 2019 If any of the TORS switches are stuck (common problem) that will ground and kill the ignition circuit. Unplugging the box will disconnect that system. Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 21, 2019 Author Report Share Posted October 21, 2019 So just unplug the TORS system and I should get spark Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 22, 2019 Author Report Share Posted October 22, 2019 Unplugged the tors plug and hopped up and cut down you where right the key switch off is on have great spark but it’s farting and sputtering but still won’t start sounds like it wants to but won’t. Smoke coming out of exhaust but won’t start. can I run the banshee with out the tors plugged in Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 22, 2019 Report Share Posted October 22, 2019 you can run it without the TORS no problem, pull plugs, kick many times, install new dry plugs and try again. Quote Link to comment Share on other sites More sharing options...
Domenick Posted October 22, 2019 Author Report Share Posted October 22, 2019 I don’t wanna stay in gas to the carburetor is awesome spark now it wants to go but won’t!! It’s two carburetors but only one has a choke is a choking and the other one to Quote Link to comment Share on other sites More sharing options...
