2015 ATC Quest Custom 8.5'x24' All Aluminum Trailer
2015 ATC Quest Custom 8.5'x24' all aluminum trailer
Weighs 3,500 pounds empty. Similar sized steel frame trailers weigh between 5,000 and 5,500 pounds. With a Razr, tools, fuel and 3 ATVs this trailer weighed right at 6,000 pounds. Pulls very easily.
16" aluminum wheels with two steel spare wheels and tires
Rear spoiler with lights
Electric tongue jack
15,000 BTU AC/Heat (will freeze or heat you out)
1" foam insulated roof
I have installed 6 24" LED lights on each side and 1 18" LED light in front over work bench. Work bench is screwed in and can be removed.
I have also installed a batter set up for the LED lights with a tender so that when the trailer is plugged in, everything stays charged. 50' RV cable included.
I have added many trailer storage components on the walls that hold a ton of stuff. They are very solid.
Trailer is very nice. I had it custom built in 2015 and will currently run $24-25,000 to build or buy. I just need a longer trailer.
$18,000
71182456_10100985881134181_1485306403714
71245209_10100985881154141_820062214335771336894_10100985881373701_8223561829972
71939105_10100985881393661_1915111838383
  • 1 month later...
