I just bought a new to me banshee and I’m looking for a little advice. All the info I have on the motor is that it’s a 421 cub. CPI in frames v force reeds keihin pj 34 carbs with k and n pods.  The bike is very boggy off idle and all the way through the mid range. I’m wondering if you guys could help me with a starting point as far as jetting goes. This is my first banshee but not my first two stroke so I feel like I have an uphill battle of trying to tune this thing.
Pull the carburetors off, clean them, check what jets are already in there and go from that.
Check and set the float level while you are at it, also would be good to check reeds and do the compression test as well as leak down test too.
Sent from my ONEPLUS A3000 using Tapatalk
