jason.perez Posted September 21, 2019 Report Share Posted September 21, 2019 I got: 97shee, t5’s, stock carbs no air box 300 feet above sea level 25 pi290 main, needle middle clip So my low end kinda weak, top end is power wheeling i don’t know if I should go down to 280 does that sound like it would be to lean? Or should I lean out the needle ? I don’t really have the space to plug chop at the moment Quote Link to comment Share on other sites More sharing options...
fixitrod Posted September 24, 2019 Report Share Posted September 24, 2019 Depends on the "bog" but I'd start with the pilot jet screw before tearing it apart. Also, verify your carb tops are tight, no choke air leaks, etc. 1/4 turn in, if it doesn't change try another 1/4 in. It should get better or worse by then. If it's worse, go the other way. If you can't get it satisfactory with the screw, dig into dropping or raising the needle or look for other very basic things first like the filter. Quote Link to comment Share on other sites More sharing options...
